GhostWheeler Posté(e) le 24 novembre 2019 Partager Posté(e) le 24 novembre 2019 (modifié) Le 22/11/2019 à 22:20, Alla Shkolnik a dit : vérifiez dans les paramètres que la tension de l'appareil est 84v I tried many time to set battery voltage to 84V but it doesn't work on ks16x. I have the same issue with the official KingSong app on IOS (pourcentage is always at 100%) trop dur pour Google translate. ? Veuillez expliquer It should be interesting to have user shortcuts with preferred parameters (depending on wheels) which can be use by clicking in one button Modifié le 24 novembre 2019 par GhostWheeler Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Alla Shkolnik Posté(e) le 25 novembre 2019 Auteur Partager Posté(e) le 25 novembre 2019 11 hours ago, GhostWheeler said: I tried many time to set battery voltage to 84V but it doesn't work on ks16x. I have the same issue with the official KingSong app on IOS (pourcentage is always at 100%) Appreciate you much for the dialogue and for English? It’s quite strange. Maybe you have tried an old DB version? We testing it on our KS16X - on firmwares 1.0.5 and 1.0.7. It’s working good enough. What exactly happening when you’re trying adjust voltage in DB? 11 hours ago, GhostWheeler said: It should be interesting to have user shortcuts with preferred parameters (depending on wheels) which can be use by clicking in one button Can you describe your preferred configurations? Like I’d say, it’s really good idea and I like it. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Alla Shkolnik Posté(e) le 25 novembre 2019 Auteur Partager Posté(e) le 25 novembre 2019 What's new in beta 5.4-238- KingSong: Added Strobe tile (Dashboard)- Gotway: Added Strobe tile (Dashboard)- KingSong: Added automatic torch mode (Device Settings)- KingSong: Fixed reading initial lights/torch statuses and riding mode- Torch Automatic has been moved to Device Settings Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
GhostWheeler Posté(e) le 25 novembre 2019 Partager Posté(e) le 25 novembre 2019 Il y a 12 heures, Alla Shkolnik a dit : Appreciate you much for the dialogue and for English? It’s quite strange. Maybe you have tried an old DB version? We testing it on our KS16X - on firmwares 1.0.5 and 1.0.7. It’s working good enough. What exactly happening when you’re trying adjust voltage in DB? Can you describe your preferred configurations? Like I’d say, it’s really good idea and I like it. I Alla, i do some test today and by removing the neuronal network option and applying 84V on voltage value, pourcentage and remaining kilometers are working correctly. Thanks you so much for your feedback and help to solve this issue. Other questions, when your last update on DB will be available in IOS store? Thanks and good job Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Alla Shkolnik Posté(e) le 25 novembre 2019 Auteur Partager Posté(e) le 25 novembre 2019 17 minutes ago, GhostWheeler said: I Alla, i do some test today and by removing the neuronal network option and applying 84V on voltage value, pourcentage and remaining kilometers are working correctly. Thanks you so much for your feedback and help to solve this issue. Other questions, when your last update on DB will be available in IOS store? Thanks and good job Glad I could help? I think in one-two weeks. It depends of testing, and Apple Review period. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Alla Shkolnik Posté(e) le 26 novembre 2019 Auteur Partager Posté(e) le 26 novembre 2019 What's new in beta 5.4-239- KingSong: Fixed changing max speed and alarms for Imperial system Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Alla Shkolnik Posté(e) le 26 novembre 2019 Auteur Partager Posté(e) le 26 novembre 2019 à la recherche de testeurs avec Kingsong 18L/XL! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Alla Shkolnik Posté(e) le 27 novembre 2019 Auteur Partager Posté(e) le 27 novembre 2019 (modifié) @GhostWheeler, FYI. DarknessBot 5.4 already in the Appstore! What's new: KingSong We had tested it on KS16X and KS16S only. - Added Strobe tile (Dashboard) - Added automatic torch mode (Device Settings) - Added Lock/Unlock mode - Added Lights mode and colors (Device Settings) - Fixed reading initial lights/torch statuses and riding mode - Fixed changing max speed and alarms GotWay We had tested in on Gotway Nikola only - Added Strobe tile (Dashboard) Non-brand specific. - Torch Automatic has been moved to Device Settings This is a first step to autonomic settings influencing on EUC/eScooter riding experience when you have several devices. Thanks eWheels and KingSong for support! Modifié le 27 novembre 2019 par Alla Shkolnik Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Olpop Posté(e) le 29 novembre 2019 Partager Posté(e) le 29 novembre 2019 Bonjour, j'ai testé Darknessbot 5.4 avec ma KS18L et ça fonctionne désormais parfaitement , y compris le réglage de la vitesse max (tiltback) et des alarmes 1/2/3, ce que je trouve vraiment pratique puisque nous dispensant de l'utilisation de l'appli Kingsong qui contraignait d'être enregistré et connecté sur leurs serveurs pour tout réglage de ce type. Là désormais plus besoin de connection avec les serveurs ni même de liaison internet. J'ignore cependant si ces réglages pourront ou non être modifiés via DB sur les roues ayant moins de 200km. A tester par ceux qui s'offrent une KS pour Noël. Les autres nouveautés - éclairage stroboscopique et verrouillage (sans code) - sont moins indispensables mais désormais accessible en dehors de l'appli KS ce qui sera apprécié par leurs utilisateurs. Merci à Ilya et Alla Shkolnik pour ces derniers développements qui ont pu être menés à bien avec l'appui de Kingsong. Bien sûr DB ne fonctionne que sur les téléphone Apple. 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Alla Shkolnik Posté(e) le 30 novembre 2019 Auteur Partager Posté(e) le 30 novembre 2019 (modifié) Merci! Sur les restrictions - nous avons laissé des recommandations KingSong: pour KS16X - 10km (sur tous les firmwares), pour KS18L/XL - 200km. Modifié le 30 novembre 2019 par Alla Shkolnik Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Valpan Posté(e) le 2 décembre 2019 Partager Posté(e) le 2 décembre 2019 Le 27/11/2019 à 06:40, Alla Shkolnik a dit : @GhostWheeler, FYI. DarknessBot 5.4 already in the Appstore! GotWay We had tested in on Gotway Nikola only - Added Strobe tile (Dashboard) Je roule en Tesla, et je n'ai plus accès aux courbes (vitesse, puissance, etc.) depuis la mise à jour. De plus, mes trajets ne sont plus mémorisés. Y a-t-il quelque chose à faire ? Merci par avance Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Alla Shkolnik Posté(e) le 2 décembre 2019 Auteur Partager Posté(e) le 2 décembre 2019 2 hours ago, Valpan said: Je roule en Tesla, et je n'ai plus accès aux courbes (vitesse, puissance, etc.) depuis la mise à jour. De plus, mes trajets ne sont plus mémorisés. Y a-t-il quelque chose à faire ? Merci par avance Pouvez-vous envoyer une capture d'écran du tableau de bord avec des tuiles de vitesse et de puissance? Et envoyer vos logs Via t Paramètres / à propos / envoyer logs Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Valpan Posté(e) le 2 décembre 2019 Partager Posté(e) le 2 décembre 2019 Il y a 2 heures, Alla Shkolnik a dit : Pouvez-vous envoyer une capture d'écran du tableau de bord avec des tuiles de vitesse et de puissance? Et envoyer vos logs Via t Paramètres / à propos / envoyer logs Merci pour votre réponse. J’ai envoyé mes logs. L’application ne garde plus mes informations en mémoire, je ne peux pas vous envoyer mes anciens trajets. Je ferai une copie d’écran demain à la fin d’un trajet. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Alla Shkolnik Posté(e) le 2 décembre 2019 Auteur Partager Posté(e) le 2 décembre 2019 1 minute ago, Valpan said: Merci pour votre réponse. J’ai envoyé mes logs. L’application ne garde plus mes informations en mémoire, je ne peux pas vous envoyer mes anciens trajets. Je ferai une copie d’écran demain à la fin d’un trajet. Merci! D'autres utilisateurs nous ont contacté au sujet des voyages perdus. Je pense que nous avons trouvé un bug dans le code, la version bêta avec le patch sera bientôt disponible. Lorsque vous confirmez que le bug a été corrigé, une nouvelle version apparaîtra sur l'Apple Store. D'un autre côté, personne n'a encore signalé un problème de vitesse et de puissance. Nous allons étudier vos journaux et attendre les captures d'écran. La chose principale que je veux apprendre d'eux est que vous avez des tuiles qui n'ont pas de valeurs? Vous pouvez le regarder hors ligne si vos données sont enregistrées. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Valpan Posté(e) le 3 décembre 2019 Partager Posté(e) le 3 décembre 2019 Il y a 12 heures, Alla Shkolnik a dit : Merci! D'autres utilisateurs nous ont contacté au sujet des voyages perdus. Je pense que nous avons trouvé un bug dans le code, la version bêta avec le patch sera bientôt disponible. Lorsque vous confirmez que le bug a été corrigé, une nouvelle version apparaîtra sur l'Apple Store. D'un autre côté, personne n'a encore signalé un problème de vitesse et de puissance. Nous allons étudier vos journaux et attendre les captures d'écran. La chose principale que je veux apprendre d'eux est que vous avez des tuiles qui n'ont pas de valeurs? Vous pouvez le regarder hors ligne si vos données sont enregistrées. Voilà les copies d’écran que j’ai faites à la fin de mon trajet. Cela précise à chaque fois qu’il n’y a pas de données pour la période sélectionnée. Et le trajet n’est pas gardé en mémoire. Merci par avance ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Alla Shkolnik Posté(e) le 3 décembre 2019 Auteur Partager Posté(e) le 3 décembre 2019 4 hours ago, Valpan said: Voilà les copies d’écran que j’ai faites à la fin de mon trajet. Cela précise à chaque fois qu’il n’y a pas de données pour la période sélectionnée. Et le trajet n’est pas gardé en mémoire. Merci par avance ! Donc, vous n'avez que des données instantanées, il n'y a pas de données sur tous les graphiques... OK, nous ferons quelques améliorations pour minimiser la possibilité d'un tel comportement du programme. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Valpan Posté(e) le 3 décembre 2019 Partager Posté(e) le 3 décembre 2019 Ok merci ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Alla Shkolnik Posté(e) le 3 décembre 2019 Auteur Partager Posté(e) le 3 décembre 2019 First trying....?What's new in beta 5.4.1-240:- Gotway: Fixed missing data on Graph and Trips Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Valpan Posté(e) le 3 décembre 2019 Partager Posté(e) le 3 décembre 2019 il y a 29 minutes, Alla Shkolnik a dit : First trying....?What's new in beta 5.4.1-240:- Gotway: Fixed missing data on Graph and Trips ? Quand cette nouvelle version sera-t-elle disponible sur iOS ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Alla Shkolnik Posté(e) le 3 décembre 2019 Auteur Partager Posté(e) le 3 décembre 2019 @Valpan, Je pense la semaine prochaine. J'espère que les tests confirmeront que le problème est résolu. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
