Trottinette Xiaomi M365 en promotion chez Gearbest au prix de 361.13 €.
Caractéristiques de la trott :
Specification:
- Model: M365
- Material: aircraft-grade aluminum alloy
- Wheel size: 8.5 inch inflatable tire
- Motor size: 6.7 inch
- Maximum torque: 16N.m
- Maximum speed: 25km/h ( common mode ), 18km/h ( energy-saving mode )
- Cruising distance: 30km
- Braking system: front E-ABS anti-lock system, rear mechanical disk brake
- Rated motor power: 250W
- Maximum motor power: 500W
- Battery pack power: 280Wh
- Climbing gradient: approx 14 degree
- Waterproof grade: IP54
- Pedal ground clearance: 87.5mm
- Max load: 100kg
- Charger rated power: 71W
- Charger input voltage: 100 - 240V, 50 / 60Hz
- Battery limited voltage: 42V
- Charging time: 5.5 hours
- Standard power consumption: 1.1kWh per 100km
- Unfolding size: 108 x 43 x 114cm
- Folding size: 108 x 43 x 49cm
- Net weight: 12.5kg
Pour en bénéficier, cliquez ICI et tapez le code GBM365FR.
Possibilité d'un cashback de 6% sur le site shoop.
Modifié par themroizo
https://www.espritroue.fr/topic/2728-xiaomi-mijia-m365-%C3%A0-277%E2%82%AC/
  • 3 mois après...
