RolluS Posté(e) le 14 avril 2016 Partager Posté(e) le 14 avril 2016 Welcome! Awesome customisation work! 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Olbom Posté(e) le 14 avril 2016 Partager Posté(e) le 14 avril 2016 (modifié) @EUC Extreme: Should I understand that this 70° tilt has been requested to GOTWAY headquarters, which accepted to do it ? I guess you are waiting for the new MSUPER (3 ?) with a possible 1500w engine ... More torque of course. You said your MSUPER is special, but is it based on type 1 (High speed) ? the 40km/h you announce sounds it. Hope the new model will have this HS option. I also like : EUC Extreme normal day... and the night video. Very funny and informative. Spiked tyre, levered up pedals, and the way the MSUPER is resting by night ... Modifié le 14 avril 2016 par Olbom Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
EUC Extreme Posté(e) le 15 avril 2016 Auteur Partager Posté(e) le 15 avril 2016 Yes. Properly understood. The video time model which was originally a beep. I have taken it off, and I use the phone for better application with precise vibrations and sounds the alarm that I can self-adjust to the speed I want. Up to 60 km / h http://l.facebook.com/l.php?u=http%3A%2F%2Fezbe.underkround.fi%2Fapp-60kmh.apk&h=uAQET4yJB Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Olbom Posté(e) le 15 avril 2016 Partager Posté(e) le 15 avril 2016 Hi @EUC Extreme, thanks a lot for the app ! Seems to work fine on my Android phone, right away ... I'll try it tonight ( maybe not the 60km/h limite ! ;-). ) 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jbwheel Posté(e) le 15 avril 2016 Partager Posté(e) le 15 avril 2016 Le 13/04/2016 à 17:42, EUC Extreme a dit : Thanks My Msuper is special. It is only available through electric-scooter-chop.com. It is Msuper V Speed. At the moment I use two Speed model. The second is to 40 km/h. And the second 43 km/h. In addition, I have 900wh lipo batteries that I can download 8 minutes Do you mean you can discharge or charge your 900Wh lipo in 8 min ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Chromium Posté(e) le 15 avril 2016 Partager Posté(e) le 15 avril 2016 You're Wheelcome @EUC Extreme That's great to see you at esprit-roue you know. Il followed some of your adventures I am a great fan. Thank's a lot for your exibition. I liked also your special slow ride Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
EUC Extreme Posté(e) le 15 avril 2016 Auteur Partager Posté(e) le 15 avril 2016 Filling. That is, the charge takes 8 min It is really true Thank you. The great thing here to note that I am already familiar to many Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) le 15 avril 2016 Partager Posté(e) le 15 avril 2016 Normal yours videos are amazing Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jbwheel Posté(e) le 15 avril 2016 Partager Posté(e) le 15 avril 2016 il y a 21 minutes, EUC Extreme a dit : Filling. That is, the charge takes 8 min It is really true Thank you. The great thing here to note that I am already familiar to many Then are you using some LiFePO4 polymer battery ? if not, you would be able to charge even faster and could have a more consistent behavior of your wheel from the beginning to the end of the battery. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Olbom Posté(e) le 15 avril 2016 Partager Posté(e) le 15 avril 2016 Hello again, @EUC Extreme, On another forum thread (Equipements), I am congratulating you for your "fantastic" body equipment. It is obvious that some are specially built. Apart from the "historical Monument" lighting system on your helmet , I am focusing on your efficient "Phalanx shell protection" on both hands. Very smart indeed : Seems very light and strong ... How did you build it ? Which material ? A few close images of them ? It is true that my Msuper High Speed gives me sensation I could go much faster : But, at this very precise moment, I remember some of my past falls ... Adapted protection is the right move to go on, no doubt ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
EUC Extreme Posté(e) le 15 avril 2016 Auteur Partager Posté(e) le 15 avril 2016 I use Revolectrix brand lipo batteries. I found them to be first-class. They are able to withstand high loading and unloading. They could download faster but. it requires chargers for more Now I download 2x60A Hand Protector is made of a malleable wood. It is a Finnish invention. It was originally designed in plaster cracks. It can be freely modified as modeling clay when its temperature is approximately 60 ° It is also easy to cut with scissors. On cooling, it hardens and can withstand frost. It can be edited freely again and again whenever the heats. It also adheres to itself, and cures immediately into one seamless piece. The substance is a mixture of wood and some adhesive mass. Pretty expensive but absolutely amazing substance. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Olbom Posté(e) le 15 avril 2016 Partager Posté(e) le 15 avril 2016 Thanks a lot @EUC Extreme, for the quick reply and info. I was pretty happy here to couple 2 standard chargers, to charge my Msuper with 4,13 A, in half the time ... And you announce 2x60A for 8mn to charge 900wh ! Your hand protections are also awesome, and of very smart concept. Highly protective, clever design, surely quite comfortable. One of your ideas ? As I understand, we are not really neighbours : Too bad ... A ride with you must be quite interesting (at least in the few seconds after the start ... ) Thanks again and all the best, EUC Extreme ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
EUC Extreme Posté(e) le 15 avril 2016 Auteur Partager Posté(e) le 15 avril 2016 (modifié) Yes. Hand Protection is my idea. http://www.woodcast.fi/en/casting/products/woodcast4mm I wonder how such a long time to implement. I made the first aluminum prototypes. They were functional but could not bear the constant burden. One of the most important criteria was the fact that they must be easy to put in your hand, and the thumb needs to get out quickly if necessary. Otherwise, its use would be extremely difficult. Apparently, we do not live close to each other I live in Finland. Hope to see you sometime .. Modifié le 15 avril 2016 par EUC Extreme Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Olbom Posté(e) le 15 avril 2016 Partager Posté(e) le 15 avril 2016 Finland ? Nice to Know ... A lot of space, of nature ... Happy Guy ! Nice set of photos indeed ! Some of us try to customise our wheels, will be helpful, thanks ... 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
RolluS Posté(e) le 15 avril 2016 Partager Posté(e) le 15 avril 2016 (modifié) Have you done any mod against snow and moisture? Ho, and you meant charge and discharge, not load and download right? Modifié le 15 avril 2016 par RolluS Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
EUC Extreme Posté(e) le 16 avril 2016 Auteur Partager Posté(e) le 16 avril 2016 I meant the charge time is 8 minutes I can also charge the terrain. I always have two 3kw aggregate in the car involved. The only thing I've done for moisture and snow is, Between the covers of silicone. There has never been any moisture. 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sbouju Posté(e) le 16 avril 2016 Partager Posté(e) le 16 avril 2016 Le 15/04/2016 à 05:07, EUC Extreme a dit : Yes. Properly understood. The video time model which was originally a beep. I have taken it off, and I use the phone for better application with precise vibrations and sounds the alarm that I can self-adjust to the speed I want. Up to 60 km / h http://l.facebook.com/l.php?u=http%3A%2F%2Fezbe.underkround.fi%2Fapp-60kmh.apk&h=uAQET4yJB This app is a special version of "Wheelemetrics"? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
EUC Extreme Posté(e) le 16 avril 2016 Auteur Partager Posté(e) le 16 avril 2016 This application has made a Finnish friend Esaj, who also run the EUC. Fortunately for me, he took a lot of my wishes into account and implemented them Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sbouju Posté(e) le 16 avril 2016 Partager Posté(e) le 16 avril 2016 OK, I understand... The esaj original post for its app is here: http://forum.electricunicycle.org/topic/1198-wheelemetrics-custom-gotwayking-song-app/ 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jbwheel Posté(e) le 18 avril 2016 Partager Posté(e) le 18 avril 2016 Le 15/04/2016 à 16:47, EUC Extreme a dit : I use Revolectrix brand lipo batteries. Can you tell us why you choose to use lipo instead of the original li-ion, is it only a matter of autonomy or did you experiment any wheel cut off in your conditions ? I couldn't find any item on electric-scooter-shop.com, only a subscribe list... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
