Montage Magura MT5E sur dualtron Ultra V2
Carbonite
Il y a 7 heures, JOHN CA a dit :
Ken, I have purchased these screws because the bleeding will be easier since the it has the bayonet screw.
But I tried to connect the fitting that comes with the Magura bleeding kit and doesn't fit.
Do you which size is this bayonet screws?
Thanks for your help!!
Hi,
you need the Formula bleeding screw, this is a Formula set.
That’s a 5 mm bleeding screw
  • 4 semaines après...
On 6/19/2020 at 2:34 AM, sonkenn said:
Hi,
That's a 5 mm bleeding screw
Hi Ken, I followed your recommendation but these screws are to short (banjo and couple of washers) and doesn't go inside the caliper enough to adjust.
So I ended up using the banjo bolt that came with de Elvedes Hydro Kit.
Also had leak issues with the copper washers. They don't seal really good and needed to get some others that came with a rubber o ring inside.
Thanks!!
Thanks!!
That’s the screws I used on my Ultra, without any issue
  • 6 mois après...
